2017 A4 performance chip
My A4 is a 6 speed manual. The performance is good. I am wondering how to achieve the increased performance of the S3 using the same engine but providing 292 HP, an additional 40 HP. Is the difference in power simply due to tuning?
It isn't the same engine.
2017 A4 Performance Chip
Originally Posted by VipinLJ
(Post 24995304)
Originally Posted by A4 fast
(Post 25010282)
Both engines are 2.0 litre turbos with direct injection. what accounts for the 40 HP difference? 252 vs 292 in the S3? Also, same engine in the GTI R?
You can do a swap for like $1400 and tune it and bam you S3 power Stage 1 style. I am not sure about the intercooler. if the A3 and S3 are the same size. The IS20 is good for about 22P{SI sustained maybe max at 25 if you keep things cool otherwise you pull timing and 22PSI makes more power. The IS38 will run around 33-36PSI tuned! |
And a good idea to check the torque ceiling of the quattro Ultra system used on the manual A4 as well, I would have thought.
Originally Posted by Glisse
(Post 25014416)
Also the trannys are different. |
(Post 24986672)
Thanks for the suggestion. I am not familiar with Neuspeed, but the Plug and Play feature seems to offer comparable performance ( 35-50 HP gain) with minimal investment ($400.00 US). What are the risks to the engine and warranty? Have you used this device or know of others who have used it? If so, does it live up to its billing and is it reliable?
(Post 25015966)
