3/4 throttle mod for the DBW T-28 is in effect & working great
full boost is reached by the same RPM as before, throttle body still registers 100% & timing is more advanced
im curious to see if others with the kit & boost controller have similar results
bleh.....
my butt dyno is good enough for me
the S4 guys have already done every test/run/log in the book so talk to then if you want some 1/4 mile times or dyno plots
maybe ill run the car once its a bit more modded, but for now the 1/4 mile is the last thing im concerened about
very popular with the S4 crowd......
if you had DBW & logged your pedal input & throttle body you'd notice that the T/B opens to 100% around 75% pedal input or so...
i hate to say do a search, but the S4 guys have beaten this subject to death & they have tons more info than i can provide in this single post
It is very simple
at 75% pedal you are still using the 02 sensor to adjust fuel trim, where as at 100% pedal your turning off the 02 sensor. So if you can hold the pedal at 75% with the throttle body at 100% you can get the car to run at a much cleaner AF ratio, that is unless your chip is tuned to do that already.
yeah...I felt my car ran stronger like this too...with APR stuff
I did the madman mod on mine. I have never VAG'd it to see if it really did make a difference, but I think I feel it.
placebo or not, i like it!
a buddy of mine has a S-III, imma see if i can get him to try this as well
you should make a post in the S-III forums & see what thier take on it is also
