Performance and Tuning Discussion forum for various performance tuning techniques and questions
Adding a PES G2 SC on a 75,000 A6 2.8 Avant ?
Old 10-09-2002, 10:04 AM
New Member
dazzyb's Avatar
Default Adding a PES G2 SC on a 75,000 A6 2.8 Avant ?
So a few years ago I picked up a nice A6 2.8 avant which now has close to 75,000 miles on it. It is obviously out of warranty now so I don't have that whole issue to worry about.
Now I want to add some performance to this thing. Infact I'd like to add a PES SC which from what I have heard is a LOT of performance (especially for the money IMHO).
My questions are:
1) Does this engine/transmission (I know, I know it's a Tip!) have too many miles on it to really make this worth it?
2) Is the PES install easy enough for a non-mechanic to do or is there anyone in the Seattle area that anyone would recommend to do the install.
3) What other mods should I do before/after/during this install? (i.e. must have the brakes to back up that power, or an aftermarket exhaust would be a nice addition)?
Thanks guys & gals,
D.
Old 10-09-2002, 12:20 PM
Junior Member
Catfish's Avatar
Default A couple of answers.
2. I did my own install and do not consider myself to be a master mechanic. If you change your oil, bleed your brakes, change your brake pads, change or clean your air filter, then I think you're capable of installing the kit yourself. Read the instructions carefully, label each part removed with nomenclature and page number, take your time [about 10 hours for me], and call PES or some of us who have done this if you get in a bind for help. You'll have to send your ECU to PES for the chip upgrade.
3. No other mods are required. PES recommends using a K&N panel air filter. I recommend upgrading your front brakes for shorter stopping distance.
I installed my G2 at 33k, now have 55k and no problems, mine's a 5 speed. I recommend the kit and the company that offers it. Here's a link to Rob Andrews' G2 owners registry. He's also got some good info on the G2 and install.<ul><li><a href="http://www.robsaudiworld.com/cgi-bin/guestbook.cgi?...">Rob's G2 Registry</a></li></ul>
DoubleB
9
04-14-2009 07:46 PM
AP Zoutes
12-09-2005 01:57 AM
FlyingWombat
06-10-2003 05:11 AM
wilson-a6
04-26-2003 10:26 AM
stickboiy
11-30-2001 12:44 PM
Quick Reply: Adding a PES G2 SC on a 75,000 A6 2.8 Avant ?
