After stage iii, cluch , twin intercooler, diferential, complete exhaut, pulleys, what...
I would buy a stand alone oil cooler
the factory oil to water one is junk...ive blown up three of them...you can get all the stuff for only a couple of hundred bucks including rad and braided hoses and sandwhich plates...keep your oil cool and you will pick up or at least stop the loss of power through heat.
looks like you've covered the bolt-ons. internals?
I also see you don't have a fly wheel listed, not necessarily adding hp, but freeing yourself of some rotational mass.
personally if I were at your point, i would be looking for ways to lighten the car.
crack her open...
port and polish, unshrowd the valves, as well as a valve job.
You can see good midrange improvements, and spool-up improvements with top end work.
If you want to go all out then build the bottom end as well.
Cheers,
Sameer
Cheers,
Sameer
N75 Race Valve!! i have the same car as yous, I bought one but im installing a
boost guage first to see how much boost im getting and will get. Ill keep you posted.
One question, you removed the CAT??? why? I have a Remus exhaust and was thinking about installing another cat, maybe that would increase HP. But you removed it completly, does this increase Hp?
will this affect the readings the CPU does?
what about noise level?
Another thing if you dont mid, what do you think about the Neuspeed intake tube? worth the $180? how does it feel?
Thanks!
Thanks!
