Another small update: Timing belt is on!
<a href="http://johnbaas.dyndns.org/2point0/audi_timing_belt.jpg"><img src="http://johnbaas.dyndns.org/2point0/audi_timing_belt_lo.jpg"></a>
This is a 155T belt and the old-style tensioner/pulley. If you look, you'll see the tensioner and pulley aren't connected. The belt is tight enough to not need the tensioner, so I'm just going to make it a fixed pulley. The tensioner is mainly on there for the small roller. I figured it couldn't hurt to use it.
With this setup, the cam pulley is 1/2 tooth off, so I may have to come up with an adjustable pulley. I've been told the 16V 2.0s use the same cam pulley......
And yes, the hood does close with plenty of clearance
Here's some pics of the wastegate actuator bracket, I had to hack it up quite a bit to get it to fit with the rotated compressor housing.
<a href="http://johnbaas.dyndns.org/2point0/turbo_wastegate1.jpg"><img src="http://johnbaas.dyndns.org/2point0/turbo_wastegate1_lo.jpg"></a>
This is a what-not-to-do pic. The oil return fitting hit the bolt for the wastegate actuator bracket. I had to grind the head of the bolt down to get it to fit. And yes, the line does fit with no problems.
<a href="http://johnbaas.dyndns.org/2point0/turbo_wastegate2.jpg"><img src="http://johnbaas.dyndns.org/2point0/turbo_wastegate2_lo.jpg"></a>
Here is the piping I'll be using for the downpipe and turbo plumbing. I'm still waiting for the silicone connectors, should be in this week.
<a href="http://johnbaas.dyndns.org/2point0/turbo_pipes.jpg"><img src="http://johnbaas.dyndns.org/2point0/turbo_pipes_lo.jpg"></a>
The box they came in:
<a href="http://johnbaas.dyndns.org/2point0/box.jpg"><img src="http://johnbaas.dyndns.org/2point0/box_lo.jpg"></a>
One small problem I came across is the turbo oil feed line has an NPT type fitting, but the oil housing has a PG (metric) thread. I need to come up with some kind of adapter for it.
The piping....
did you actually figure out what sizes your gonna need already? Or were you gonna cut/weld(frankenstein) the stuff together yourself?
Man, it's good to see people follow through with big projects like this. I can't wait to see her up and running. Then you can make room in your garage for my car=P
I bet that belt was a bitch. A few Q's:
You're going to run it without the tensioner?
Is that wise? I've never heard of anyone using a timing belt without a tensioner.
I think you should just convert the timing system over to chain and be done with it
Good luck, and nice job!
Most engines don't use tensioners when running. They have a "tensioner spring" to help make sure
teh mechanic doesn't over tighten the belt or keep it loose. Once the mechanic tightened the locking bolt, the tensioner pulley is fixed, similar to xr4tic's setup.
Turbo inlet piping is 3", turbo outlet piping is 2" I bought some silicone connectors......
to tie it all together.
Basically, there will be a silicone 90 degree bend on the turbo inlet, that goes to 3" 90 degree tubing, then the MAF and filter.
The outlet will be going over the frame rail, straight down, then curve back to go into the stock crossover tubing (which is 2")
It's all going to be cut/welded together.
Exactly, plus the tensioners allow a little bit of movement, for when the belt stretches over use...
and the tensioner will keep it tensioned correctly.
I plan on replacing the belt much earlier than the recommended 60k, probably every 30k or so, and will be inspecting it probably every oil change or so.
I hope so....
the 90 degree silicone tube is a tight bend. I was going to turn it to the side, but I might hit the headlight.
Otherwise, I'll go down, then back up, kind of like what SmokinA4Turbo did:
<img src="http://pictureposter.audiworld.com/11056/3vr6_maf.jpg">
I could always pull the headlight off, would be great for a ram air setup
