Anybody have a link for a Dual weber Carb
local spitfire has a 4AG :) if you have the weber manifold and you should be good to go
if you want a better ignition system to go with that i recommnend HPX
no more dizzy <img src="http://pictureposter.audiworld.com/12079/106562844nhsvpp_ph.jpg">
dcoe's
I had trip 40DCOE's on my GT6. just lots of noise 'till I did the full kas kastner race spec rebuild. Choked bores at 29mm iirc, for 6500 power peak.
Verify a swing spring is in the rear suspension.
whats the displacement? i got 1600cc and already changed some parts on my brand new carbs (45)
thing with carbs is its highly dependent of the porting and cam profiles.<ul><li><a href="http://members.aol.com/dvandrews/webers.htm">anyway, here's something to read</a></li></ul>
