Anybody know the specs of the Schrick cams on 1.8T, i did a search but can't find the answer.
I run the bigger of the 2 hyd and car dyno'd to 360 at APR. The Dahlback kit I am doing is for 440hp
and uses these cams. I will be upgrading some comp. in the valvetrain, but some feel the cam is good for 500crank and above> I know a guy in Europe who gets 500whp out of his cams, but they are solid and a pain to adjust to be sure.
rod
rod
i got the spec. from Schrick N. America distributor - Denon Performance (more)
specs:
intake 252 degrees duration, 8.2mm lift
exhaust: 260 degrees duration, 10.4mm lift
by the way, Audi2ptzero.
you have the techtonics adjustable cam gear, right? how did you set the schrick cams with the cam gear? -2 degrees?? or +2 degrees??
thanx in advance
thanx in advance
übertek
Mid Atlantic Discussion
09-25-2006 08:21 AM
eug (MK V)
02-07-2006 10:43 AM
vwfoxtuner
06-06-2003 08:52 PM
