Anyone with a 2001 1.8tqm with APR stage 1...
If you've got a 2001 car with APR stage 1 and EMCS, and you're so inclined, would you mind doing a simple test (especially if you're in a cooler climate)?
Pick a stretch of highway, pick a landmark; approach in 5th gear at 2400rpm, then go wide-open throttle and time the run from 2400-3400rpm (approx. 51-72 mph). While absolute numbers may not be meaningful, I'd be interested in seeing your chipped mode vs. stock mode results on this test. (and note your air temp as well)
Thanks!
-dan
Thanks!
-dan
No racing, not real racing anyway
There is for certain more Umph in the car with a chip than w/o a chip. I'd describe it as how the car should have come directly from the factory.
maxZugkraft
02-15-2005 08:41 AM
Silvr1.8T
03-19-2002 02:19 PM
ALR
04-18-2001 01:59 PM
unA4dable
01-25-2001 06:54 AM
