Performance and Tuning Discussion forum for various performance tuning techniques and questions
anyone ever run a K04 on a 2.0 stroker?
Old 04-05-2005, 10:26 AM
Justin517's Avatar
Default anyone ever run a K04 on a 2.0 stroker?
I ahve 118,000 miles, and will prob keep my A4 forever, or close to it. I also HATE turbo lag. Im considering rebuilding my engine once it starts approaching 200,000 miles, and was considering a 2.0 stroker kit. Is that way too big for a K04? I dont realy wnat to go bigger than a K04 because i liek ahving boost right off idle, and realy dont care much about power above 6500 or so RPM. I just wanta ton of torque. Or would i jsut bhe better off with a stock rebuild with maybe forged rods and pistons, or is that even overkill? Basicaly if I had ported and polished head, intake maifold, exhaust manifold (or custom tubelar header), camshafts (if dahlback can do the programing for them, wich i think they can)K04, FMIC, bigger injectors, and programing to work with 93 octane, what kind of power would i be capable of? would it be a waste with the K04? I imagine that the little K04 would help low end torque alot and with the better breathing of the port and polish the top end would improve slightly also? I imagine a 1.8 would work better than a 2.0 with this setup? or is more displacement always better?
thanks very much.
Old 04-05-2005, 11:00 AM
Enclave's Avatar
Audi2ptzero (Mike) did.
Old 04-05-2005, 11:39 AM
Justin517's Avatar
anyone know how it worked out?
Old 04-05-2005, 04:42 PM
PanTTher's Avatar
the new 2.0T uses a K04. why wouldn't it work out?
Old 04-05-2005, 06:25 PM
Imolavirus@BuehnEngineering's Avatar
Default you could go a little bigger than a K04 without an inrease in lag if you're increasing
displacement as well.
Old 04-05-2005, 06:33 PM
Enclave's Avatar
No, it uses a newly designed K03.
Old 04-05-2005, 08:48 PM
PanTTher's Avatar
Default Still don't understand your concern. Do you think it's too big ot too small?
my 1.8t used a K04 & it was fine. You should have very good response with your 2.0.
if the new 2.0T uses a K03 then a K04 should be just fine with your 2.0.
Old 04-05-2005, 08:54 PM
Elder Member
Audi2ptzero's Avatar
Default Ran ok but the K04 is too small for a 2 liter.
I had 7psi while revving out of gear and full boost around 2200 rpms. YOu want to go with a GT28 with the 2 liter, this will have good spool up and good power.
Old 04-05-2005, 08:56 PM
Elder Member
Default You can run the K04 but you will have to run it at very low boost.
Even at 1 bar of boost the turbo will be fully spooled and you wont have much power over 4500 rpms. Go with a one of the mid size turbo kits.
Old 04-06-2005, 07:46 AM
Banned
ModifiedA4's Avatar
Default you're not understanding how turbos work...its a bit complicated
<center><img src="http://www.s4biturbo.com/k03/S4K03big.jpg"></center><p>
Quick Reply: anyone ever run a K04 on a 2.0 stroker?
