Anyone know what typical EGT for a chiped car should be
I have a 02 A4 with APR 1+ and, I am haveing problems with my O2 sensor it was replaced last week, I am getting this fault code. also if the O2 sensor heats up will it fail?
1 Faults Found:
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 008 - Implausible Signal - Intermittent
and my EGT's at 80mph are around 900 degrees C. is this normal? What range or tems should i be incurring?
1 Faults Found:
Where's the EGT probe located?
if it's in the collector of the manifold, then that's probably about right, maybe slighltly on the high side though. I use to see ~1500F when cruising at 80mph.
Then I relocated the probe to the #4 runner, and the temps are ~1350-1400F when cruising.
audiquattroduo
11
11-13-2008 02:46 AM
Sal R.
06-29-2006 07:49 AM
mattd860
02-21-2005 05:59 PM
mrsteve
05-15-2003 08:04 PM
