attn: Pelican Blue-T28
I'm going to be helping Resse with his EVO FMIC install and I understand be got it from you, correct? If so, will I need to re-locate the secondary air pump? Also, did he get all of the piping you were using? What else will need to be done for install?
thanks... josh
thanks... josh
You should have 2 pipes one for at the turbo and one that has the boost sensor fitting on it
Yes you will need to move the smog pump over or to the other side of the car where the stock IC is at.
I'm not sure...
I have a feeling I might get to installing mine before we install Resse's. Either way though, I'll let you know beforehand. Which one are you looking at installing?
islingtonaudi
SoCal Discussion
05-20-2007 07:16 PM
lemond33
09-23-2006 07:15 PM
seeyas4
04-21-2006 07:21 AM
kontakterr61
07-23-2004 03:15 PM
allroad(s) lead 2Gavin
06-22-2004 10:12 AM
