attn: xr4tic or Audi2ptzero It took me 2months just to do block 31 log
<a href="https://forums.audiworld.com/performance/msgs/61102.phtml">Post from the past</a>
Is there a conversion factor for V to a/f ratio?
And the dip for the throttle is from me deciding whether or not the pass the subaru infront of me
Well, here it is plus a boost log:
<img src="http://members.shaw.ca/dannykso/lamda.jpg">
<img src="http://members.shaw.ca/dannykso/115.jpg">
Converting V -> A/F ratio
Check out the link.
Use the graph to convert v -> lambda. Then use the table to match a lambda value to the A/F ratio.<ul><li><a href="https://forums.audiworld.com/performance/msgs/61950.phtml">https://forums.audiworld.com/performance/msgs/61950.phtml</a</li></ul>
Well your info is correct for the 2001 and newer A4's since they read in lamda.
The pre 2001's read the other way around where .9 is richer and .7 is leaner. Both have 12.5:1 around .85
