Autronic standalone
Autronic standalone
I have an Autronic smc on a 2000 S4, engine is stock apart from K04's from RS4, RS4 injectors and AWE intercoolers, My problem is I cant get it running nice, does anyone have this system on their s4? And got a map they would like to share?
email: gromit4x4@yahoo.co.uk
Dont think anyone has it running on a S4 or A4 at this time.
Why did you pick to go that way when GIAC already has a chip for the K04 kit and is now using the Mobile Tuner to fine tune it and get more power out of it.
With a good tuner you will get more w/Autr. / Motec than motronic, unless you have keys to Audi
Some tuners have access to secrets some dont, but only Audimotorsport and those who help them can make motronic better than a hi end standalone, and Autronic qualifies.
This is really pretty easy once sensors get matched, they have a prog that gets you 85% without program,ming
Who got you into this anyway? BTW taking the rs4 turbos to limit on an unbuilt bottom end will toast engine.
The s4 and the rs4 engines werent that close to each other. I have a friend who got 410whp out of a s4 engine following speedvision rules, then found out that the rs4 used cosworth heads, and the car was being built to go against the rs4's w/factory support. He gave it back t customer when he couldnt get the rs4 heads. Very fast track car now, the equal of the rs4 speedvision cars except the head and the missing 80hp. He used MOTEC M88.
Rod
Rod
Re: With a good tuner you will get more w/Autr. / Motec than motronic, unless you have keys to Audi
Thanks for the replies. I didnt know about audi world untill recenly, hence this is my first post. I am in the UK and there is no GIAC agent over here.
Re: Autronic standalone
Fast Enough Performance (Lexington, KY) is a VW-Audi tuner shop and an Autronic dealer. I think the owner uses Autronic in his Rallye Golf and his Ur Quattro. 859-258-2015<ul><li><a href="http://www.autronic.com/dealers.html">list of autronic dealers worldwide</a></li></ul>
Mark P
15
04-29-2003 05:00 PM
Dose anyone know if the engine compartment on the RS4 is bigger than the S4 or are they the same siz
KEVS4
04-02-2003 05:03 PM
Ghant TMK
25
03-07-2003 11:04 PM
GiVeMeAuDi(egg)
12-13-2002 12:29 PM
captainbilly
05-17-2001 12:13 PM
