Performance and Tuning Discussion forum for various performance tuning techniques and questions
Boost and cold weather...
Old Jan 22, 2003 | 02:20 AM
Digit@lex's Avatar
AudiWorld Expert
Default Boost and cold weather...
Seeing that it's about 10 degrees outside how much boost can I expect to lose? I have a T-28 that spikes to about 21 PSI and settles to 17-18 PSI at WOT in 3rd gear. Is this normal?
I am thinking that it would normally spike to 23-25 PSI and then settle at 20 PSI.
Thanks.
Old Jan 22, 2003 | 11:13 AM
Ray Khan's Avatar
Default apples to oranges, but in the minus 5 we had
up in NH over the weekend...I was seeing only about 16 lbs of boost. Then again I've got a different turbo/programming and I'm DBW. I was hitting about 20 psi back when it was in the teens and twenties.
Old Jan 23, 2003 | 03:35 AM
Digit@lex's Avatar
AudiWorld Expert
Default Good enough comparo...I was just curious as to how much boost people were losing in the cold.
I will probably change most of my hoses and clamps spring time. Any recommendations for those? Samco?
Thanks.
Old Jan 23, 2003 | 07:07 AM
Ray Khan's Avatar
Default I have a few OEM hoses I'm reusing right now that I shoudl probably replace as well
I don't know what else is out there other than samco.
Old Jan 23, 2003 | 08:28 AM
Yippers®'s Avatar
Member
Default Plain old 'merican vacuum hose works good, is cheap and readily available. The only silicone I have
is the short piece that runs just above the turbo to the APR intake hose (due to the heat of the turbo in that location). All the other hoses are just vacumm hose from NAPA or similar.
Old Jan 23, 2003 | 08:42 AM
Ray Khan's Avatar
I think that's the piece I want to replace...thanks.
Old Jan 23, 2003 | 08:47 AM
Yippers®'s Avatar
Member
Np ...
Old Jan 23, 2003 | 09:59 AM
cuatrokoop's Avatar
Default Re: Boost and cold weather...
Colder air is already more dense, so you aren't really loosing boost, its just not needed to produce the same amount of power as it was in warmer ambient temperatures...
Old Jan 23, 2003 | 10:16 AM
Ray Khan's Avatar
yep...ecu is jsut trying to meet a loadd demand
Old Jan 24, 2003 | 07:51 AM
Digit@lex's Avatar
AudiWorld Expert
Default Same here. I have already replaced my vac lines with rubber hoses...
with great results.
I would like to use the expensive stuff for the high heat prone area which is what Yippers described.
ModifiedA4
Jan 17, 2007 11:39 AM
MMBRAZIL
Audi Original "S" Cars
Jul 3, 2006 07:40 AM
BLK01S4
56
Apr 27, 2005 07:24 PM
cpayne
Oct 11, 2003 05:23 PM
