BOV Install, pros.......cons?
Not lean, it will cause momentary richness. Will that be a problem eventually?
Probably, depending on how and where you drive. Bosch motronic leans out a bit for a brief period when the accelerator is depressed because instant dump of fuel on acceleration can wet the chamber. Adding a BOV may defeat that purpose I imagine.
Best to do is a hybrid one which a few people use but I don't know if they are adept at diagnosing cause and effect. If no CE light, then it means their way of driving and the engine condition can be compensated by the ECU.
One test would be is to take the car to the fast race track (not very technical). Drive a few laps, examine the spark plugs. Install the BOV, drive a few laps again and then examine the plugs. Darker means too rich.
Or you can log the O2 and fuel trim if you have a VAG.
Slightly rich is better than slightly lean but you are just overworking your cat and eventually foul out the spark plugs.
only reason for a BOV is the distinctive poseur woosh sound. BPV might keep the
turbines spinning slightly faster even, although i'd bet there's no perceivable difference in performance between the 2. worst is you're venting metered air per Audiboy's observation...
TabulaRasa
Audi Original "S" Cars
10-18-2007 04:44 AM
