Bum KO3 on 98 A4
Bum KO3 on 98 A4
Dealer just told me I have a bad bearing in my K03, suggested replacement. It does make loud noise under heavy power. Can I get any performance gains with just adding a new k04 without any other mods?
Do you have a chip in your car now?
I remember reading how some chips for the K03 can be run with a K04 with no problem, but others could not (or wasn't avisable)
You should be fine just swapping turbos, the K04 will run more efficiently at higher boost levels, so it will make more power.
If you got a chip for it, you will also need to put more fuel in, so you'll need to get injectors or a 5 bar pressure regulator. But I'm sure you'll like the results
audi1.8t4life
05-29-2008 04:14 PM
TJHUB
07-22-2005 02:57 PM
Dr. Steelo
05-18-2004 07:13 AM
theodore
07-31-2003 05:04 AM
Hawaiiannights
08-05-2001 08:21 AM
