Performance and Tuning Discussion forum for various performance tuning techniques and questions
Cam shafts
Old 11-07-2002, 07:00 AM
PAD
New Member
PAD's Avatar
Default Cam shafts
Has anyone changed the camshaft in their 1.8? Seems like a good way to make hp. Question; does the head have to come off to remove cam or is it a drop in affair? I'm used to old BMW's where one had to remove the head vs old VW's where you could just drop in a cam. The dealer would never know!!!!
Old 11-07-2002, 07:11 AM
cuatrokoop's Avatar
Default Re: Cam shafts
Which 1.8? 8v, 16v, 20v? Turbo, non turbo?
Old 11-07-2002, 08:08 AM
4kq
Member
4kq's Avatar
Lol, and check the archives. Lots of good posts.
Old 11-07-2002, 09:18 AM
Elder Member
Audi2ptzero's Avatar
Default I put in a set of Schrick cams in my built up 1.8t motor.
But you will need a chip to make it all work with the cams.
Old 11-07-2002, 01:22 PM
Senior Member
CharlieGSanD's Avatar
Default aren't you running on a stanard chip?
what changes do you think are needed? i would have thought the ECU would be able cope with the changes
Old 11-07-2002, 02:36 PM
Elder Member
Default Car runs rough at idle. I also run on race chip with 91 octane
just to get enough adv timing to make the car run right.
On a non dbw A4 the motor is going to run lean because the cams are going to allow more air flow thru the cylinder. I am still waiting to get the car tuned on a dyno.
Old 11-07-2002, 04:44 PM
Senior Member
wouldnt that be that from your lower compression, not the cams........
Old 11-07-2002, 07:13 PM
Elder Member
Default Running rough at idle is from the cams. Letting in a ton more air is from the cams too.
On a non dbw car you would still need to have the chip tuned for the extra air flow. I need to have my idle bumped up to 1000-1100 rpms.
Old 11-07-2002, 11:06 PM
Senior Member
so what does advancing the timing have to do with anything?
Old 11-08-2002, 07:36 AM
Elder Member
Default Adv timing has to do with my motor not the cams.
Adv timing was about my motor. I put the rest about tuning a chip for the cams.
I am running a standard K04 chip but the car is no where near 100% tuned.
Quick Reply: Cam shafts
