Which cams and pistons r better 4 the $?
I just recently upgraded to the K04 and am being told eventually my cams and pistons will wear out. What r good cams and pistons that arent too pricey?
capeA4 used shrick with a k04
you might want to talk to him. The cams won't wear any any significant rate because of those mods. From what I've been told by a few people the K04 won't push enough air to gain much from cams. Cams are going to run you nearly $1000 and the labor will be a bit much if you are paying to have it done. Obviously if you are going to do pistons and build the bottom end, the labor for the cams won't be as bad as doing the cams alone. I would hold off until you NEED them done i.e. catostrophic engine failure.
