Can I get some pics of peoples catch can set ups....
No pics of mine, but the can is just under the coolant reserve
mounted to the bracket that is connected to the ABS unit. I know a few others that also have it mounted in the same place.
Here's someone's catch can post
I just unhooked mine, slapped a filter on facing down and kinda let it do its thing. I should probably get a real catch can at some point...<ul><li><a href="https://forums.audiworld.com/a4/msgs/315837.phtml">https://forums.audiworld.com/a4/msgs/315837.phtml</a></li></ul>
here is mine....
<center><img src="http://www.wseng.com/a4/catchcan/breather.jpg"></center><p>i also have some plugs available to close off the hole in the intake hose that the PCV valve would normally sit in....
Easier than that...
The can has a "sight tube" and is accessible from underneath. Just pull the sight tube when you are changing the oil and drain it into your oil pan.
-Dave Pramanik
-Dave Pramanik
