Can I have the stock A4 flywheel lightened?
I'm not talking anything super major, since taking too much off may make the flywheel unsafe.
The reason I ask is I just lost 2nd gear, so I have to pull the trans. I can't justify spending $1K for a new flywheel/clutch, especially since my current clutch (stock) has only 18K miles on it.
If I can do it, how much weight do you think I can shed? 4 or 5 lbs maybe?
Thanks,
Thanks,
I would on mine when the time comes. It would help me Auto-Xing, but I'll have to be more cautious
on a road track because lift throttle oversteer will be more evident, and I use quite a bit of throttle modulation to try to make the end come slightly around. Other than that, revs would just drop faster, but just as some V8 american cars, I had no problems driving them smoothly with passengers. Legs cramp more though :P
The stock flywheel is a dual mass unit, so lightening it is no easy task.
You would be hard pressed to shave of 1-2 lbs from the stock unit.
An aftermarket clutch kit, like ours, converts the flywheel to a single mass aluminum unit (13lbs lighter), and then uses a sprung center clutch disc.
That way, you have easy take-up characteristics (clutch disc), while letting the engine rev like a superbike (aluminum flywheel)!<ul><li><a href="http://www.awe-tuning.com/products/audi/audiparts.cfm?PMaI=1&PMoI=1&PEI=2&PP=a4_18t_drivet rain.cfm&PPT=Drivetrain">April special on A.W.E. AEB clutch kit</a></li></ul>
Jeff 'S iv
10-01-2007 04:49 PM
dbtong
07-18-2001 07:32 AM
