can i utilize a catch can on a dbw b6? iirc i believe i've heard i may not be able to b/c of...
emissions issues that are not a problem on earlier dbc b5's. If so, anyone know where to look for one? TIA
Any car with a catch can will fail just the visual inspection.
You can put one on your B6 the same way we put them on the B5.
ok, thanks, why is there an emmissions issue with it anyway?
Because the way it is setup now is so the oil vapor is
burned off instead of released to the atmosphere with a catch can with a filter. Now if you put in a catch can that just traps the oil but feeds back into the intake track before the turbo like it does stock, then you should be ok. But that just stops some of the oil vapor not all of it and does not help with added vacuum issue a larger turbo will cause.
thx
i have a greddy can for sale, still in the box... $80?
