Can a non-resistor spark plug such as the Beru Silverstone be used on the 1.8T?..............
Can the 1.8T handle these plugs? Or will it run into EMI and RFI interference troubles?
The whole system is sensitive to EMI according to audi...
Radios are just sensitive EM receivers, if you get enough interference the ecu can also have sporadic errors. This is why audi advises to use care when installing transmitters (re. manual).
All aftermarket ecus that I have seen describe the requirement to use resistor plugs and wires to avoid interference.
Broker
Canadian Discussion
11-27-2002 02:59 AM
JCJiffy
08-24-2001 10:16 PM
