Can someone explain the function of the Vac line that connects to the BPV?
NOTE: The tech at my dealership said these vaccum lines fail a LOT!
He said I should keep an eye on the top half of the vaccum line that accuates the bypass valve (the small cloth-covered one) and make sure it does not become broken or cracked. He said they have had a lot of failures of this hose. I guess the hose must become brittle from the heat.
Possibly off-topic, but just FYI.
If you change your bypass valve I would recommend also changing the bypass valve actuator vaccum line with one made of some high-temperature silicone(sp?).
Paul
'98.5 A4 1.8TQTS (52K mi.)
Paul
mattarios2
11-26-2005 11:44 AM
rmonckton
11-24-2005 12:56 PM
Tony1997A4
04-09-2002 03:08 PM
CharlieGSanD
09-29-2000 12:30 PM
