CEL back on......does "misfire detected cyl 1" mean that i'm running on 5 instead of 6cy
CEL back on and have yet to replace 02 sensors....rough and erratic idle at times. I noticed a black dust under the exhaust tip(running rich), is there any way aside from 02 sensors to fix this; possibly reprogrammed ECU or adjustable fuel pressure regulator. I noticed when CEL was off for 5 days straight i had an increase in performance/ does DTC Misfire Detected CYl 1 shuft of my first cylinder?
Brad
97 A6 Q 2.8 12v v6 SOHC sedan-schrick 260,stebro custom cat backT304, ported throttle body, cold/ram air K&N, EIbach Pro kit, Bilstien sport struts, Orbital slotted Fronts, Raybestos PG Plus fronts, stereo(too long to list),etc.
Brad
Misfire DTC doesn't "turn off" the spark signal sent by the ECU...
The DTC is just a "stored fault" to let the technician know the cylinder has had weak/non-existing spark at some point in the past.
mmdambro
04-11-2011 06:05 PM
CO2000A418T
04-16-2005 08:13 AM
