CEL and a code of - 17544 "Fuel trim bank- System too rich". Any ideas? On my '99.5 w/ 26K miles.
you have an air leak..
check intake pipings and charge pipings.
check block 032
first field shows air correction when idling (most likey intake to turbo) should be +-10%
second field shows air correction when driven (most likely between turbo and throttle body)
max +-20%
check block 032
max +-20%
It's my girlfriend's and we bought it with 14K last year. I did some logs last night...
Block 031 .855 at full throttle so O2 sensors are good. Block 032 I believe these values were 14% for the first block and like 3% something for the second block. I'll check again. Those are nowhere near the values Havepitty gave.
Unfortunately, that's not a good O2 test....
O2 sensors are only accurate at 14.7:1 ratio, and over time, they drift due to use or contamination.
I'd reset the ECU, do a TB adaptation, and then let it idle for a while, and see what the idle % (1st value) does. Then drive it on the freeway, and see what the PT % does (2nd value)
If it's a negative value, then you're running rich, and the ECU is removing fuel based on the O2 sensor. If it's positive, you're running lean, and the ECU is adding fuel.
It could be a bad MAF also.
N9909E
04-01-2006 01:15 PM
marcodant
10
11-02-2004 07:16 PM
OHQuattros(tehblur)
03-23-2004 05:12 AM
