Changing to Mintex...but do I need pads with sensors for my early 96 A4?
When I went to order my brakepads (Mintex Reds), the shop asked if I had brake sensors. Without having to take the wheel off, how will I know? Do certain models have these sensors? Mine is very early 96...first purchased/sold on October 95.
Thanks in advance...as usual!
if the 99 has the wear sensor, then you should get pads w/sensor.
If you have the sensor on your car, but you do not buy pads with the sensors, you will need to run a loop in the car's sensor, where is connects to the brake pad sensor. Otherwise, your brake-wear indicator will always be on.
PeteH
PeteH
CarNut68
Audi Original "S" Cars
12-08-2008 10:47 PM
Pic of front brake pads with sensor (on rotor) please. I need to determine does mine require or not.
BSCA4
09-30-2002 08:00 AM
