Could somebody give me a quick run down on the pros and cons of lightweight flywheels?
Mainly the cons. They've been on my mind a lot recently and I don't want to be sure I'm not forgetting some major downfall or am otherwise ignorant of any liabilities they can cause.
They can make you car sound like a deisel at idle...
They require much more gas and feel at launch since there is less mass and momentum in your engine. IMHO a lightweight clutch is good if you are into racing/drag, etc. My son just did it in his stage 3 GTI and it has no day to day value.
I run a 12lb. FW on my A4 and it sounds normal at idel and drives fine everyday in traffic.
It takes a bit more care to launch it, but other than that I find it easier to drive daily. It is certainly much easier to match revs for proper shifting. If you've driven a car with a LW flywheel that was not practical as a daily driver, it's likely that it was due to the aggressiveness of the clutch and not the flywheel per se.
I did a 12lb with a big clutch at the same time..
and I find it more fun to drive, feels faster (not sure if it is or not, butt dyno sucks)...
it is BIT more difficult to drive in bumper to bumper, but I think that is more the clutch...
I would never go back. Makes stock cars feel heavy and syruppy.
Get it.
Get it.
Rotating items have inertia, not momentum, "same" concept though...
I've also never heard a car with a light-weight FW sound like a diesel. Only ones that did had POS pressure plates, clutch discs or release bearings. Design flaws (Centerforce LT1/T56 clutch disc had a design problem, at least on some 4th gen Z28's I knew).
Northern California, On the way back from gold bluffs... there are a few more...
<ul><li><a href="http://public.fotki.com/skabaru/travels/2003_oregon_trip/audrey_back_from/">pics from my fotki...</a></li></ul>
So when breaking in a new SB Stage 4 clutch can I "get on it" once in gear and clutch fully engaged?
Allroady DungBeetle
07-12-2007 07:18 AM
Godfather | Jay
10-25-2006 06:31 PM
archimense
9
09-24-2006 09:04 PM
