Dahlback is in...opinion and some questions
I love this chip, I dont have alot to compare it to but i did beat an RSX type S. It peaks at almost 20 psi when floored , drops to 17 by 4200, then 15 around 5500, and holds 12-13 to 6600 where i shift, dont see any real need to rev it higher than that.
My CEL came back on, 1136 is the OBDII code, i had it once before when my N75 valve **** out. the car surges at WOT below 2800 rpm or so. All turbo inlet, outlet and IC tubes are tight, new FPR and DV vaccum lines. I ahve an EVO billet DV and a new turbo. I tested my N75 w/ an ohm meter and got around 30 ohms, when i researched that seemed right. It is a 1997, maybe i need to update to a newer MAF b/c im maxing the older style one out? Do FPR go bad? I dont know when my fuel filter was last changed, deff not within the last 25,000 miles, im doing that today. any other possibilities?
I already ahve an EVO DV...can i maybe rig up a stronger spring? i dunno if evo makes one.....
if its enough for a modded porsche, i would think it would be enough for my chipped 1,8T?
would anyone suggest a 5 bar FPR? im going to ask the shop i got the......
chip from but id liek to know what the experts on here have to say also. thanks for all the help.
-Justin
-Justin
Could be.. but...
I ran with the second Forge Spring and it was great..smooth but just a bit off top end power. (2.7T) Then the day I switched to spring 1 I had a bad launch, the clutch slipped the eRPMs when to 7 grand, I went in to safe modde. and then heard the turbo lady sing.....
So... I like Forge with spring 2...for you Spring 3 may be needed.
