Difference between air-to-air and liquid-to-air ics?
One uses air to cool the fins while the other one uses water to remove the heat from the air
charge. The bad thing about air to water is that you have to also cool the water and there is a greater amount of weight added. Since you will need a holding tank, pump, water lines, fittings the IC and something that will alow the water to be cooled off. You are also sucking power from the motor with the small pump.
markbradford
12-08-2003 09:49 AM
