Does anyone have any tips on getting the stock turbo out?
I've gotten far enough in my install where I have the stock manifold off and the turbo is hanging loose but I can't get it out. The oil return line keeps getting snagged on things so Im having trouble pulling it through. I can't get to the bolt to remove the line so I cant get it off. Did anyone else run into problems like this?
Re: Did you drain all the oil and unbolt the oil return line from the oil pan?
Yes, I did all of that, I'm just having trouble with the getting the oil return line to clear everything on the way up. It keeps snagging on everything imaginable.
Found this was still connected too, but I can't get it off...
<center><img src="http://pictureposter.audiworld.com/3953/turboline1.jpg"></center><p>I realized this was connected but I cant figure out how to get it off because it is really hard to get to. I think it is the coolant return line. Once I get this off I should be able to get the thing out pretty easily.
Like I said earlier, that is the coolant hose.
That is the coolant hose that bolts up to the block and has a bango fitting on the block side of the turbo. If you look up from under the car you will see what I am talking about.
boxster02
16
01-24-2008 01:14 PM
Flippa_S4
09-14-2007 12:13 PM
aride4
01-11-2007 12:58 PM
TJHUB
07-30-2005 11:02 AM
Hibi Red 98.5
03-14-2005 01:14 PM
