Experiencing some issues with my oil pressure gauge... any thoughts?
On a cold start, when accelerating the gauge will read up to about 75 psi - shouldn't I be reading higher than this? When the oil temps get warm, at 3000 RPM's and higher, the gauge just stops at 50psi. Won't go any higher (will go down to 20/25 if I decelerate to idle) ... it "flutters" a bit, as if it's trying to go higher but can't. It's a 100psi gauge and a 100psi sender.
At idle when warm, the gauge reads between 20 and 25 psi (pretty normal). Specified range for 3000RPM's when temp is warm is between 62.5 and 78psi (IIRC) - do I have a leak somewhere that's only showing once I generate enough oil pressure in the system (ie, over 50psi) ? I think the gauge is fine as it'll read over 50psi on a cold start, just won't read over 50 once she's warm.
I'm going to disconnect my senders and stuff this week and reconnect them a bit tighter with some more thread sealant... any other suggestions? Thanks.
what type of oil do you use? and what oil change intervals
Could be this new oil sludge issue. I was talking to one of the techs. at my delership and he said that if I ever had any issues with oil press. to bring it in as that could be the culprit.
I use M1 5w/30 and change at 5k intervals so I hope it won't be a problem with my car.
An_A_car
Audi A3 / S3 / RS 3
01-28-2007 06:35 PM
'81 tic-tac
06-01-2003 12:41 PM
Jason Chen
09-10-2002 06:05 PM
