A/F Gauge owners: Does the gauge read all yellow at idle?
No. On a good running engine, it should fluctuate from almost full rich to almost full lean.....
You may have it hooked up wrong? Does it go full rich during WOT?
WOT=wide open throttle
I must have installed it wrong, at 2-3K in 1st gear it's near full rich.>
Omori boost and Autometer A/F are the gauges I installed.
Here's what I did:
I soldered the ground and accessory power from both gauges together.
Grounded it outside the driver's fuse panel.
Powered it from the 75X, under the dash.
I soldered the violet wire to the blue wire from the pre-cat 02 sensor harness. It is black before the harness, then after the connector it turns blue.
I tapped after the harness because that's what Autometer's directions said to do.
Also, when I started it this A.M., the car was shaking, but the car seemed to drive OK. Weird...
Here's what I did:
There's two wires. One may mislead you, the other is correct.
<center><img src="http://pictureposter.audiworld.com/21967/mat_reid_a4_interior_1.jpg"></center><p>
I tried to get a picture of a wiring diagram for you, but the picture poster wouldn't take it for some odd reason. For a '00 1.8T, the wire you want to tap into should be grey(at the sensor), brown on the other side of the connector. At the o2 sensor there's a black with a white stripe, don't know where you got a black wire from, unless you have a different year car?
Black wire on the TT......>>
Tapped at the connector....Works fine
<img src="http://images.fotki.com/v4/photos/7/7305/125312/DSCF0064-vi.jpg">
Gauge from Autospeed (australia)
<img src="http://images.fotki.com/v5/photos/7/7305/125312/DSCF0067-vi.jpg">
I've got one grey, but it doesn't turn into brown.
<center><img src="http://pictureposter.audiworld.com/23968/02_harness.jpg"></center><p>
model year 1998.5
#3 (grey) is grey before the connector too.
#4 = black
#'s 2 & 3= white
model year 1998.5
#4 = black
#'s 2 & 3= white
Mr. Bungle
08-10-2006 11:33 AM
mdwsta4â„¢uroslut
11-08-2002 06:17 PM
Keyna
11-05-2001 07:09 AM
