FRONT AUDI ADJUSTABLE CAMBER KIT
Anyone want to lower there car should look at this adjustable camber kit first.<ul><li><a href="http://www.nascarplace.com/kmac/itmidx1.htm">http://www.nascarplace.com/kmac/itmidx1.htm</a</li></ul>
Re: FRONT AUDI ADJUSTABLE CAMBER KIT
<ul><li><a href="http://www.nascarplace.com/kmac/">http://www.nascarplace.com/kmac/</a</li></ul>
Details?
Has anyone used this kit? For 300 USD is it really worth it for street use? I dont believe so.
It is if you run some serious drop and need to adjust your camber
There is no rocket science to most of these...must mean Audi is finaly a volume car
Somehow I would think this would be more interesting to race guys looking for more camber, rather than street guys looking for less.
like 60mm or more i take it.
No, strongly disagree.
The A4tqms I run needs the camber kit to run a flat tire *period*: The problem is it knocks me right into SP. The basic chassis has no proper camber, causing the tire to overheat on the outside and not use the inside, and it only get worse when racing. Other than the massive weight, this IMHO is the real impediment to competition with this car.
Agreed
My car with just Eibach springs and Bilstein shock is at the limit on streetable camber. I have about 1.5 degrees of camber. Any more, I'd be getting some unacceptable tire wear.
How much did you lower it from Stock Susp.?
