H&R ultra performance coilovers or Vortrag fixed height suspension
Both are about the same price, which would you choose and why? I am looking for a true performance setup.
Thanks,
Chris
Thanks,
Chris
I've tried both...
... and they are both good setups. I wound up going with a modified H&R system: 625F/665R lbs. uprated spring rates, twin-stacked springs (mainsprings and helper springs separated by a coupler); the rears, after much experimentation, are now very similar to an UltraPerf--they have tapered springs to avoid rubbing against the shock body. The resulting system (with different swaybars F & R) is very trackable. It is stiff but tolerable on the street and only clunks when you hit a major road imperfection. Most people would find it a bit extreme. The Vortrag system is a little more civilized for the street. The H&Rs are double-adjustable (vs. single for Konis, I think) and permit a very low ride height--I can send you a pic if you want). Your call, both are fine.
Lee in D.C.
Lee in D.C.
suspension ?.coilovers or springs and shocks?thinking H&R eibach bilstein 1.75 inch low as i will go
MaXiTT
01-13-2002 11:17 PM
Driver With No Name
08-23-2001 07:41 AM
dannyboy
05-09-2001 11:29 AM
Audimus Ed
Performance and Tuning
04-23-2001 08:31 AM
