Performance and Tuning Discussion forum for various performance tuning techniques and questions
Has anyone thought about wrapping the crankcase pipe with exhaust wrap?
Old 09-01-2003, 06:10 PM
QGMika's Avatar
Default Has anyone thought about wrapping the crankcase pipe with exhaust wrap?
I find that it produces just as much heat as the turbo...
<img src="http://pictureposter.audiworld.com/35825/dscn2968.jpg">
<img src="http://pictureposter.audiworld.com/35825/dscn2969.jpg">
Old 09-01-2003, 06:29 PM
Elder Member
Audi2ptzero's Avatar
Default Most likely hot because it sits above the turbo.
If it was hot because of the pressure coming out of it would then hurt performance since that pressure is then pushed thru the IC tube and into the motor.
Old 09-01-2003, 07:57 PM
QGMika's Avatar
Are you saying that pipe isn't supposed to be hot?
Old 09-02-2003, 05:54 AM
xr4tic's Avatar
Default I don't think it would do much....
It mainly draws air out of the crankcase and into the intake tube in front of the turbo, but it's not a lot of air.
The best thing would be to run a new line away from the turbo, and have it go to an oil separator.
That way you'll have cooler and oil-free air.
Old 09-02-2003, 06:28 AM
Elder Member
Default It shouldn't be that hot
Your oil temps are around 230-250 deg while your exhaust pipe is going to be much hotter then that. It would be better to wrap that oil pipe to keep the heat from the exhaust manifold from heating it up. I would do that on my car but use a catch can so I dont have to worry about it.
Old 09-02-2003, 10:16 AM
QGMika's Avatar
Default if i ran a catchcan, do i need this valve attached to the intake?
<img src="http://pictureposter.audiworld.com/35825/dscn2978.jpg">
Old 09-02-2003, 11:50 AM
Elder Member
No you wont since the catch can will replace all of that.
Old 09-02-2003, 12:32 PM
xr4tic's Avatar
Default Depends on how you have it setup.....
If you use a breather/catch can, then no, you won't need it, but if you use an oil separator setup (no outside vent) then you will need it.
IMHO, the oil separator is the best way to go, since a breather will act as a vacuum leak under part throttle conditions.
Spadde
10
08-04-2009 11:09 PM
Sloooo4esT
Audi Original "S" Cars
15
11-17-2004 02:15 PM
ModifiedA4
03-30-2004 12:43 PM
LQQKQIK
12v V6 Discussion
37
12-06-2003 07:42 AM
Quick Reply: Has anyone thought about wrapping the crankcase pipe with exhaust wrap?
