Have to replace 5-speed in 96 A4 2.8 quattro . HELP! ???
Hrm. you think the clutch master + slave will need to be changed too?
why? i'm guessing it might bolt up...i wsih somebody with $$ would try it.....
would allow us to use the rs4 clutch. teehee.
You could do the RS clutch if you do the RS flywheel....
but then you're looking at adding a lot of weight, since the V6 flywheel is going to be even heavier than the stock 1.8 flywheel.
If someone came out with a lightweight V6 flywheel, it would probably be worth it.
piper.gras
01-23-2011 09:12 PM
mattd860
03-09-2005 09:07 AM
Jersey John
08-02-2004 12:08 PM
shorki_07
02-16-2002 11:20 AM
