Help with Block 32 Readings
Re: Help with Block 32 Readings
you have a boost leak at part throttle. The first is your fuel trims for idle, the second number that's way off is your fuel trims for part throttle.
Check your boost lines....
Also check the air intake hose (aka turbo compressor inlet hose), bpv/turbo outlet to pancake pipe hose and pancake pipe to intercooler hose. If still no luck, buy a pressure tester (I think AWE sells them) and pressurize the system to find the leak.
Sloooo4esT
Audi Original "S" Cars
9
08-18-2006 07:59 AM
El Desamparado
13
06-22-2006 10:28 AM
njskier (A4i)
08-08-2005 08:25 AM
Imola4
10
11-09-2004 07:18 PM
andre d
11-21-2002 10:34 PM
