Help me decide if I am on the right track with my GReddy PRofec B-spec II boost controller settings
Ok this boost controller has the following modes:
1.OFF Mode
2.LO Mode
3.HI Mode
LO and HI Modes have the following settings that you need to set:
1.SET (0-100%)-This mode is used to set the desired boost pressure. The % set in this mode is not the actual boost pressure. This feature controls the dute rate of the Valve Unit which controls the boost.
-Raise the % to increase the boost, and lower % to decrease the boost.
-100% setting will boost up to the turbocharger/wastegate's limit.
-0% will boost the base boost (stock boost)
2.GAIN (0-100%)-This mode is used to adjust the boost consistency (Adjusts the sensitivity of the valve control.)
-When boost spike occurs, lower the GAIN value.
-When the boost falls off at high rpm, or the boost increases as rpm increases, raise the GAIN value.
-Even if the SET boost is not changed, by increasing the GAIN value, it will increase the boost.
3.START BOOST (0-43.5psi)-This mode is used to adjust the boost response. This feature basically adjusts when to start opening the wastegate.
-If the START BOOST value is closer to the SET boost value, the spool up will be faster.
-If it is too close to the SET boost, it will cause the boost to spike.
4.WARNING (0-43.5psi)-This mode is used to adjust the WARNING setting. An alarm will sound when boost reaches the warning setting.
-Set to the maximum boost level you do not want to exceed.
5.LIMITER (0-99%)-This mode is used to adjust LIMITER to lower the boost when the boost exceeds the WARNING setting. (This will lower the entered % from of the SET boost valve duty rate to lower the boost)
-99% will trun off any boost control. (back to stock boost)
-0% will disable the LIMITER feature.
As of right now I have my controller set at the following:
LO Mode:
SET 90%
GAIN 50%
START BOOST 17psi
WARNING 18psi
LIMITER 50%
HI Mode:
SET 95%
GAIN 50%
START BOOST 23psi
WARNING 24psi
LIMITER 50%
Do you guys think this is a good place to start after reading the above info? My setup is listed in my sig.
Any help would be great.
Thanks! and sorry for the long post!
1.OFF Mode
2.LO Mode
3.HI Mode
LO Mode:
SET 90%
GAIN 50%
START BOOST 17psi
WARNING 18psi
LIMITER 50%
HI Mode:
SET 95%
GAIN 50%
START BOOST 23psi
WARNING 24psi
LIMITER 50%
~DonQPremiumTequila~
07-29-2005 05:59 PM
WoostaS4
09-30-2002 01:08 AM
Phishie [K04]
04-04-2002 10:27 PM
