Here it is! My write up on my Aquamist 2d install / experience / results... (long & BWW)
AudiWorld Expert
Here is the original post with the updates:
<a href="https://forums.audiworld.com/s4/1743767.phtml">https://forums.audiworld.com/s4/1743767.phtml</a>
AudiWorld Expert
8/30/04 - I added UPDATES to my original post. They include...
The updates include:
...I will also take pics and update this post with:
- The FIA unit inside the car as well as the yellow LED and switch that I added (to turn the system off). They will reside on the the lower left section of the driver's knee bolster.
UPDATE 8/30/04 - Here they are:
<img src="http://ctny.audiworld.com/mark/s4/aquamist/DSC00910.JPG">
The Yellow LED and Swith are mounted in a modified Radio Shack project box, and that unit and the FIA unit are mounted on either side of the OBDII port. I can see all 3 LEDs from the driver's position through the steering wheel:
<img src="http://ctny.audiworld.com/mark/s4/aquamist/DSC00908.JPG">
- The engine bay with all covers in their proper locations.
UPDATE 8/30/04 - Here it is, looks mostly stock:
<img src="http://ctny.audiworld.com/mark/s4/aquamist/DSC00904.JPG">
and
...Likewise, multiple gear runs would really show this off. Consider if I had started this 4th gear run at the end of the previous 3rd gear run. My starting temps of this run would already be 20F cooler, and by the end of this run I could be up to 40F cooler than a 3rd & 4th run without Aquamist. Now continue that thought and add in 1st and 2nd gears, and the difference gets bigger. (UPDATE 8/30/04 - I logged and added these results below)
UPDATE 8/30/04 - I logged a pair of 1st-4th gear runs (10mph-120mph) in 87F weather. I did this with Aquamist off, then again with it on, both times starting at the exact same location. Below are the results, once graphed with time as the x-axis and the other time with MPH. Notice the extrem difference - across this range, IAT increases by ~50F (127F to 177F) without Aquamist, but with Aquamist IAT only increases by ~20F (126F to 146F). As early as 40mph, there begins a drastic difference in the Intake Air Temperature.
<img src="http://ctny.audiworld.com/mark/s4/aquamist/iat_10-120mph_vsTime.gif">
<img src="http://ctny.audiworld.com/mark/s4/aquamist/iat_10-120mph_vsMPH.gif">
and
IL_Allroader
Audi allroad
06-16-2008 10:25 AM
Mark P
09-01-2004 05:27 AM
Mark P
11
08-31-2004 05:42 AM
sIcAoNe
08-07-2003 12:15 PM
O.W. Kenobi
18
08-26-2002 06:09 AM
