Performance and Tuning Discussion forum for various performance tuning techniques and questions
Heres a good problem for all you tech heads...
Old 11-14-2000, 02:57 PM
Lucas_Gchips's Avatar
Default Heres a good problem for all you tech heads...
I am working on a 97 a4.18tqm at the moment.
Every time you start the car, you get 2 dtc errors codes.
One is the Loss of Bat power, same when you disconnect ecu. This should not occure when starting car..
The other error is the idle speed controller.
tried clearing them a number of times, but a soon as you start the car, the errors come back..
Old 11-14-2000, 03:17 PM
Member
Todd/A.W.E.'s Avatar
Default Sounds like you may have a loose/high resistence connection to the fuse box/battery...
Each time you start the car, the current draw from the starter may be causing the constant 12V supply to the engine ECU to drop too low, hence the low power code. Starting the car while the ECU is dropping out will also corrupt the t-body settings, which can result in the idle speed fault. Have you checked t-body adaptation at data block 98? It is probably corrupted.
Old 11-14-2000, 03:18 PM
Member
I should have said: check your main grounds, too.
Old 11-14-2000, 07:15 PM
Default Thanks Todd/A.W.E.
I was think along those line last night, but it was getting late..
The car has had a after market cruise control fitted, I wonder if some wiring was upset or not installed correctly...
ehren
07-07-2013 05:04 AM
DxC
03-17-2008 01:27 PM
VerrÜckt
29
10-30-2006 05:30 AM
Merkin
04-11-2002 03:04 PM
Quick Reply: Heres a good problem for all you tech heads...
