Here's the newest idea for the oil cooler, instead of an external setup....
<center><img src="http://pictureposter.audiworld.com/21967/dsc09936.jpg"></center><p>This is off of an S4, looks to be about 150% compared to the 1.8T A4 part. Anyone have any comments or suggestions? Stock cooler maintains about 212(?) during hwy driving(not *******), and I'd guess the S4 one would do close to the same under more extreme driving.
Parts cost from audi dealer would only be around $300, comes with seal, but
you also have to get the hollow threaded shaft, which is only like $15. Everything would install simply and in under an hour. I was saving it for my track car(sig), but am considering putting it into my daily driver first...
I'm sure the cooler could be bought for less from a different source....
I think this is the same as the dieselgeek...
I believe this is the same part that dieselgeek sells.
I've heard you can get it cheaper directly from Audi or VW than their price of $210, but I'm not sure how much.
Either way I think it is better than an external oil cooler, because it warms up the oil faster as well as cooling it off more effectively. I would think an external oil cooler could make the oil too cold in some climates. And this looks more stock.
-Ian<ul><li><a href="http://www.dieselgeek.com/oilcooler.htm">Dieselgeek's Oil Coolers</a></li></ul>
But the coolant warms up faster than oil...
and the warmer coolant helps warm the oil up.
This is probably more critical for a street car that operates in cold climates than a dedicated track car.
GBW
01-19-2009 06:34 PM
SteveBBay
03-17-2006 12:48 PM
keman
10-03-2005 11:32 AM
