Hey guys, does the oil pressure in the 1.8t ever go above 80psi?
You T it in right here...
<img src="http://johnbaas.dyndns.org/2point0/audi_oil_press_lo.jpg">
That's with the motor sitting on the stand, but there is plenty of room with the motor sitting in the car. IIRC, I tapped into the oil pressure switch, and the other sensor is the oil temp.
It's a standard NPT fitting.....
It's either 1/8" or 1/4", don't remember. The T fitting has 3 female ends, as does the oil housing. Then I used a female-to-female adapter (looks like a small pipe with threads on the outside) to join the two
I can't give you any part numbers or anything, my dad has a whole drawer full of misc. NPT fittings. You should be able to get all the stuff from Home Depot or the like.
