How do I get 250hp at the crank with my B6 1.8T??
It seems that the KO4-15 and the EO-5 will not do it. Then you step all the way up to a GT28 set up which is any where from 270-300 from what I understand.
Is the SKO-4-15 my best bet when it is available for the 04's?
ANy input or ideas are appreciated.
Why are you looking at hp, you should be looking at tq if the car is a daily driver.
Now for tq the K04-15 can give you power since it spools up so soon. Yes the E05 and Super K04 can also do that but you must remember that both of those are hybrids and are not built by 3K at all. The larger kits like the PES and T28 both make around 270-280 hp on pump gas but that is at full boost of around 20psi and you could always lower that boost level to get a nice 250-260 hp/tq.
Re: How do I get 250hp at the crank with my B6 1.8T??
If you believe in vag.com 'But Dyno',
My K04 setup with merely 315c.c. injectors runs 252 hps and 275lb/ft torque. intercooler is a must.
tuned by Revo.
tuned by Revo.
MTM Stage 3...
The following is on my quattro only boosting to 1.3bar. I am currently boosting to 1.6bar and have seen Jet Jockeys dyno gains using the same n75K on his mtm stage 3 make an additional 40lb/ft of torque. These numbers are at the wheels:
<img src="http://pictureposter.audiworld.com/57072/dyno6green-gd.jpg">
Re: Crazy Andrew
Too Funny.
Last time I was in the Evo my legs turned purple. It turns out those seats cut off all the circulation to my legs. I could only get two of the five points belts to fasten also and at that I was folded into a small package.
How did the breAKS turn out? Talk to you soon.
Andrew
Andrew
Re: Crazy Andrew
Good stuff.. Sure ain't no race car though.. Took a ride in this one today.. and the 371whp S4 when it was there.. So that EVO is not get "gangsta" <ul><li><a href="http://forums.vwvortex.com/zerothread?id=1541462">http://forums.vwvortex.com/zerothread?id=1541462</a</li></ul>
imok
09-20-2005 07:53 PM
Tsle
12-23-2003 11:22 PM
Mark P
12-08-2000 04:46 PM
