How to hook up 92 Corrado tach to the
Re: How to hook up 92 Corrado tach to the
You will need a tach signal converter. The corrado Cluster does not understand the digital signal from the AEB ecu. You can get the tac signal converter from Momentum Motors in Canada. This is what was needed to get the signal correct on my friends 91 Corrado with a AGU motor, same as AEB but german spec non dbw Audi A3 / MK4 golf 1.8t<ul><li><a href="http://www.momentummotor.com/">Momentum Website</a></li></ul>
Is that a G60 cluster that you are using ?
If so, no need to use that tach signal converter.
Send it to Adrenalin and they will modify it for you.
tryingtogofast
06-15-2005 01:37 PM
