how much should a S4 transmission swap to an A4 run w/ parts
Re: how much should a S4 transmission swap to an A4 run w/ parts
I have done it, and have reworked it.
originally i used a fabricated left side trans mount, but have 3 failed units.
I just completed a V6 Front subframe swap, now i can use the originial S4 trans mounts.
What you basivally need
s4 transmission
s4 rear diff
s4 center drive shaft
set of a4 rear diff flanges
s4 shifter and linkages
s4 trans mounts
v6/s4 front subframe
and that about it.
s4 transmission
s4 rear diff
s4 trans mounts
and that about it.
I had a trans for free, and it still ran me $2400 in parts, which included a new OEM clutch too though. I had to pay $700 for the center driveshaft, & found a used dif for $500. You'd be best to call Dad's auto, good luck! Used 6 speeds don't go for less than $1600!
Wait a minute, that's a good idea.......
I never thought of that! I've got a good A4 dif, and the S4 dif in my car is noisy. So, if I got a ring & pinion, it would go in no problems?
Sweet.....wonder how much the parts will be.
SMOKINA4TURBO
03-04-2005 09:30 AM
$240 worf of puddin
Pacific Northwest Discussion
03-22-2004 01:06 PM
Thermal
06-29-2002 05:44 AM
2002, 27t, a4, audi, b5, conversion, interchange, manual, plate, s4, swap, tanny, tranasmission, transmation, transmission
