Performance and Tuning Discussion forum for various performance tuning techniques and questions
With the huge K04 back order are any tuners working on an E05 based kit for B5 A4's??
Old 11-05-2003, 10:09 AM
QuiksilverS4's Avatar
Old 11-06-2003, 04:39 AM
Senior Member
AWOT extra 23052's Avatar
Default How huge of a back order?
A friend bought an MTM SIII kit from Hoppen and they couldn't even tell him when the KO4s would arrive. Wonder why the backlog? Maybe, AoA has decided to drop the KO3 from the A4 lineup and replace it (starting MY 04.5) with KO4s? Hehehehe, I wish.
Old 11-07-2003, 08:48 AM
Banned
Mat Indukts Lambos's Avatar
Default The E-05 is a direct bolt on for the A4 1.8T. You'd need gaskets, seals, etc......
and a set of 225 TT injectors. Once you have all that, get a K04 chip in your ECU, and you're set. If you want a package put together, email me. AFAIK, the E-05's are readily available, and the rest of the stuff needed should be as well.
Old 11-07-2003, 08:52 AM
Default Mine is 99.5 Non-DBW, does that make a difference??
and would you expect it to be any more powerful than a regular K04 or more responsive??
Thanks.
Old 11-07-2003, 06:22 PM
Banned
Default Non-DBW is preferred in my mind. As for power & response,
I won't lie to you. All I know is what I've been told, too. E-05 is supposed to be stronger/more durable/slightly higher cfm rating, but basically the same map. Responsiveness should be either a little higher on the rpm's, or identical.
Old 11-07-2003, 08:02 PM
Thanks Matt. One of these days I'll have to stop bye the shop and see you and Ed.
üBER.QIK
01-10-2007 04:24 PM
Kevin_AKA KevinECM
14
03-22-2005 11:03 AM
RikiTik
12-01-2003 11:37 AM
QuiksilverS4
11-06-2003 05:12 AM
KrautRice_A4 atl-atl
06-12-2001 06:18 PM
Quick Reply: With the huge K04 back order are any tuners working on an E05 based kit for B5 A4's??
