i put 100 octane in and no more surging/pinging. felt like 15-20 hp gain
<ul><li><a href="https://forums.audiworld.com/a4/msgs/732558.phtml">X-post to A4 forum</a></li></ul>
not if you aren't set to a race mode
Even a chipped ECU will not advance the timing enough to take advantage of 100 octane unless it has a specific race mode.
You could get some boost, but largely you are wasting your money. Mix 100 Octane and 91 Octane 50/50 and you will likely get the same effect for less money unless you have a 100 Octane chip.
if you have been following my detonation problems, you'd understand why im using it
<center><img src="http://pictureposter.audiworld.com/8383/dsc00001.jpg"></center><p>and how i could see such a big improvement
see any problems here?
drbobs4
23
04-16-2003 07:11 PM
What octane should i use? here in mexico its only available 92 octane, should i use octane boost, if
TTEBERTT
9
10-15-2001 06:00 PM
Does anyone have the URL or chart that lists the octane ratings after blending 100 with 91 octane???
BigTT
08-11-2001 02:43 PM
