Performance and Tuning Discussion forum for various performance tuning techniques and questions
I'm going to tune my A4 1.8T Q up to 400HP , so does it harm the trans ?
Old 03-14-2007, 02:03 PM
New Member
Al Audi02's Avatar
Default I'm going to tune my A4 1.8T Q up to 400HP , so does it harm the trans ?
Hi everyone , I'm going to tune my a4 1.8T q with 5 speed trans up to 400hp , that with the use of unichip , APR stage 3 kit, and changing cams , cluch , piston rods . Is that harming the trans ?
also , I live in hot and humid climate , so is there any ( overheating ) problem that I may face in future ?
please let me know .. Thanks alot ..
Old 03-14-2007, 02:27 PM
New Member
Al Audi02's Avatar
Default Re: I'm going to tune my A4 1.8T Q up to 400HP , so does it harm the trans ?
My car year is 2002 ..
Old 03-14-2007, 07:50 PM
Ertman's Avatar
trans will be fine, you will need a beefed up clutch
Old 03-15-2007, 06:51 AM
initialA4's Avatar
You will need an intercooler, and also perhaps beef up your internals
Old 03-15-2007, 07:43 AM
Member
2.0GT35's Avatar
Default The 5 speed in the B6 is weak, might want to search on the B6 forum.
At this point my B5 2.8 trans is holding up fine with the 500+whp I make.
Old 03-15-2007, 11:58 AM
New Member
Al Audi02's Avatar
Default Re: trans will be fine, you will need a beefed up clutch
Thanks alot for the information ..
Old 03-15-2007, 12:00 PM
New Member
Al Audi02's Avatar
Default Re: You will need an intercooler, and also perhaps beef up your internals
Thank you very much for that ..
Old 03-15-2007, 12:04 PM
New Member
Al Audi02's Avatar
Default Re: The 5 speed in the B6 is weak, might want to search on the B6 forum.
I appreciate your help ..
Old 04-09-2007, 07:33 PM
Lucas_Gchips's Avatar
Default Be prepared to spend some money if you want it to last.
B6 internals are very weak in the conrod area.
The engine is far weaker than previous model B5 engines.
The oil control ring is also much to be desired in these engines.
Essentially look at buying new pistons, and rods to start with.
It seems that 300HP is upper limit on these engines before you have to pull them apart and change some essential parts.
Or you can by some kit that vendor overstates the power if its just a figure you want to tell your friends.
Old 05-25-2007, 03:42 PM
New Member
ZenTT's Avatar
My 01 tt 5speed with a quafe lsd and clutch/flywheel kit could not handle the stock apr stage 3 kit, the gears were nuked within 20k miles of the install. Ended up costing 5 grand to get a real gearset put in, it would of been much cheaper to have it done when the cluch lsd and flyweel where done...
http://www.aptuning.com/products.php?productid=533
DPDISXR4Ti
01-02-2011 11:03 AM
LightningFlash
12-30-2007 07:57 AM
eisman.s4
02-22-2006 01:17 PM
Josh05
06-17-2004 01:47 AM
Quick Reply: I'm going to tune my A4 1.8T Q up to 400HP , so does it harm the trans ?
