Interesting stuff on brake fluids.....
Brake Fluid Comparison Chart
Brand Wet Boiling Point Dry Boiling Point
Castrol SRF 518°F 590°F
Motul 600 421°F 585°F
AP-600 410°F 572°F
ATE-Super Blue 392°F 536°F
Valvoline 333°F 513°F
Castrol LMA 311°F 446°F
Ford HD 290°F 550°F
Wilwood 570 284°F 570°F
PFC-Z rated 284°F 550°F
AP-550 284°F 550°F
A word about brake fluid.
xxx recommends Castrol SRF or Motul 600 due to their high wet boiling points. All brake fluids absorb moisture, some faster than others (except silicone which is not recommended for anti-lock brake systems). Castrol SRF resists moisture contamination (non-hydroscopic) more than any other fluid we tested, therefore change intervals can be greatly extended. This reduces the effective cost over a season of racing. Many drivers say that they can run the same fluid all year long with only bleeding off the fluid in the calipers for each event. This way a can or two will last all year. Other fluids (hydroscopic type) require additional flushing of the system for each track event to maintain the lowest percentage of moisture and the highest boiling point. For cars over 3000 pounds on high speed road courses xxx recommends brake fluids that do not fall below 400°F wet boiling point.
AP-600 410°F 572°F
Ford HD 290°F 550°F
AP-550 284°F 550°F
AudiWorld Expert
I have SRF in my S4 Avant...
I didn't pay $70 bottle for it...only $48 per bottle. Still very expensive...I plan to sip it like a fine wine after I bleed my brakes next time. I went to the SRF after my stock brake fluid boiled over at a 100 degree track event.
I have Motul in my race car. Both are good.
A4NCAR
01-14-2004 06:16 PM
FNKYnoS4
07-29-2002 08:58 AM
A6Fiend
08-24-2001 01:29 PM
