Just got Bosch F5DPOR plugs they come gapped at 0.6 mm (.24) for my A4 1.8 any problems with using
this gap size. I know stock is .32. what gap tool should I use, they look different from other plugs I've seen.
<img src="http://pictureposter.audiworld.com/8982/f5dporplatin.jpg">
Are you sure that is the plug for the 1.8T?
<center><img src="http://pictureposter.audiworld.com/1009/spark_plug_close_up.jpg"></center><p>Mine have always been three electrode Bosch models...and yes that electode is missing which is why you see a picture of a dead turbine wheel as my sig. THANKS BOSCH!
Mike O.
Mike O.
Try 0.028 inches (0.71mm) as a starting point for a chipped A4 1.8T...
...0.032 inches is OK for a car running 7-9psi of boost. Higher boost means more Nitrogen (from air) in the gap, thus greater resistance to spark travel.
you will be fine with thier stock gap
but.....they are a colder plug & can foul if you are a slow driver or don't really "work" the car enough to keep it up to temp
ive been running some for about 5k now & they have been good to me
dont forget to use a bit of "anti-sieze" on the threads before you install the plugs
spiralsmurf
Audi Original "S" Cars
13
08-26-2005 04:26 PM
HKG_RS4
05-31-2004 06:37 PM
Sourdough Josh
09-26-2002 08:36 AM
mike
03-17-1999 12:51 AM
